  3. Delete DRC mark
  • State Suggested Answer
  • Answers 1
  • Views 9619
Delete DRC mark
ivy372
ivy372 over 2 years ago
Hi Sir,
The skill code show the error as below:
But I only need 1 refdes & 1 error that  the error is the minimal airgap.
axlSetFindFilter( ?enabled '(noall drcs) ?onButtons '(drcs))
Markers = axlGetSelSet(axlAddSelectAll())
DRC2_Markers = setof( x1 Markers rexMatchp("Externally Determined Violation" x1~>name))
 (foreach x1 DRC2_Markers
  (foreach y1 remove(x1 DRC2_Markers)
   a = atof(flatten(x1~>actual))
   b = atof(flatten(y1~>actual))
    (if a > b then
     (if x1~>violations~>parent~>parent ~>refdes == y1~>violations~>parent~>parent ~>refdes then
      axlDeleteObject(x1)
error message
=> E- *Error* mapcan: argument #2 should be a list (type template = "ul") - "1.42308 mm"
data
Skill > DRC2_Markers~>??
((prop propList:0000024D26285128 bBox
((63.2025 9.3075)
(63.8375 9.9425)
) readOnly
t objType "drc" waived nil
layer "DRC ERROR CLASS/TOP" xy
(63.52 9.625) violations
(dbid:0000024D143A6698 dbid:0000024D143BB940) type "PAD to SKT Gap needs >= 1.5mm" source "Golden-finger keepout area"
fixed nil parent dbid:0000024D10BC2D30 expected
"1.5mm" actual "1.42308 mm" name "Externally Determined Violation"
(prop propList:0000024D26285140 bBox
((63.9325 8.8775)
(64.5675 9.5125)
) readOnly
(64.25 9.195) violations
(dbid:0000024D143A6728 dbid:0000024D143BB620) type "PAD to SKT Gap needs >= 1.5mm" source "Golden-finger keepout area"
"1.5mm" actual "1.4966 mm" name "Externally Determined Violation"
(prop propList:0000024D26285158 bBox
((69.5324 6.4325)
(70.1674 7.0675)
) readOnly
layer "DRC ERROR CLASS/BOTTOM" xy
(69.8499 6.75) violations
(dbid:0000024D143CFA90 dbid:0000024D143BB0A8) type "PAD to SKT Gap needs >= 1.5mm" source "Golden-finger keepout area"
"1.5mm" actual "0.9864 mm" name "Externally Determined Violation"
(prop propList:0000024D26285170 bBox
((70.6825 5.8826)
(71.3175 6.5176)
) readOnly
(71.0 6.2001) violations
(dbid:0000024D143CFA00 dbid:0000024D143BB0A8) type "PAD to SKT Gap needs >= 1.5mm" source "Golden-finger keepout area"
(prop propList:0000024D26285188 bBox
((70.6825 6.9824)
(71.3175 7.6174)
) readOnly
(71.0 7.2999) violations
(dbid:0000024D143CFB20 dbid:0000024D143BB0A8) type "PAD to SKT Gap needs >= 1.5mm" source "Golden-finger keepout area"
(prop propList:0000024D262851A0 bBox
((64.6625 9.3075)
(65.2975 9.9425)
) readOnly
(64.98 9.625) violations
(dbid:0000024D143A6578 dbid:0000024D143BB620) type "PAD to SKT Gap needs >= 1.5mm" source "Golden-finger keepout area"
Skill > DRC2_Markers~>actual
("1.42308 mm" "1.4966 mm" "0.9864 mm" "0.9864 mm" "0.9864 mm"
"1.4966 mm"
How can I fix the code?
Thanks~
  • DE202408202727
    DE202408202727 over 2 years ago +1 suggested
    You possibly want something like this: axlSetFindFilter(?enabled, '(noall, drcs), ?onButtons '(drcs)) externalDRCs = setof(drc, axlGetSelSet(axlAddSelectAll()), drc->name == "Externally Determined Violation…
  • DE202408202727
    0 DE202408202727 over 2 years ago
    externalDRCs = setof(drc, axlGetSelSet(axlAddSelectAll()), drc->name == "Externally Determined Violation")
    drcSymbols = unique(flatten(externalDRCs ~>violations ~>parent))
    foreach(symbol, drcSymbols
      symbolDRCs = setof(drc, externalDRCs, member(symbol, drc ->violations ~>parent))
      otherSymbols = remove(symbol, unique(flatten(symbolDRCs ~>violations ~>parent)))
      foreach(otherSymbol, otherSymbols
        symbolToSymbolDRCs = setof(drc, symbolDRCs, member(otherSymbol, drc ->violations ~>parent))
        furthestDRCs = mapcar('cadr, cdr(sortcar(mapcar(lambda((drc), list(axlMKS2UU(drc ->actual) || 0, drc)), symbolToSymbolDRCs), 'lessp)))
        externalDRCs = setof(drc, externalDRCs, !member(drc, furthestDRCs))
        axlDeleteObject(furthestDRCs)
  • ivy372
    0 ivy372 over 2 years ago in reply to DE202408202727
    Thanks~ Dave,
    But I just only keep the mark of the circle errors as below~
    Just only show the min airGap mark~
  • DE202408202727
    0 DE202408202727 over 2 years ago in reply to ivy372
    I don't understand.
    The other DRC markers are system generated so you will need to waive them or hide the layers they are on.
  • ivy372
    Hi Dave,
    I want delete the other DRC markers, just only keep one error marker closer the goldenfinger.
    Thanks a lot~
  • DE202408202727
    Hi Ivy,
    Only you will know the logic that needs to be applied.
    Deleting DRC markers is easy. Knowing which ones to delete is up to you.
    My code gives you a technique for sorting on closeness.
    Kind regards,
    Dave
