  3. difference between IPC2581A , B , C and 1
  • State Verified Answer
  • Views 6976
Sumesh V
Sumesh V over 2 years ago
Can anyone explain the difference between IPC2581A, B, C, and 1?
  • VVRD
    VVRD over 2 years ago +1 verified
    They're revisions of IPC2581. IPC2581-1 and IPC2581-A are obsolete. IPC2581-B is the most widely used version and IPC2581-C is the latest revision. You can use depending on your manufacturer. Please check…
  • VVRD
    +1 VVRD over 2 years ago
    They're revisions of IPC2581. IPC2581-1 and IPC2581-A are obsolete. IPC2581-B is the most widely used version and IPC2581-C is the latest revision. You can use depending on your manufacturer.  Please check out below link
    shop.ipc.org/.../ipc-2581-standard-only
