  3. How to enable the particular class DRC.
  • State Verified Answer
  • Views 8332
Ram1234
Ram1234 over 2 years ago
Hi Team,
Good day!,
I was look for a option that " How to enable the particular class DRC in layout.".
so please help me to find the option to enable the particular DRC error class.
Example: Enabling the short error only for a particular layer.
Ram.
  • VVRD
    VVRD over 2 years ago in reply to Ram1234 +1 verified
    You can use Analysis modes to enable or disable any DRCs as shown below. Use Color Dialog box to change DRC color for each layer.
  • VVRD
    0 VVRD over 2 years ago
    You can control DRC options through toggling the constraints in Constraint Manager -> Analyze -> Analysis mode or Setup -> Constraints -> Modes. Coming to your enabling DRC for particular layer, you can do it through color visibility tab by turning on DRC of that particular layer
  • Ram1234
    0 Ram1234 over 2 years ago in reply to VVRD
    Hi VVDR ,
    Good day!,
    I would like to enable the Design Rule Check (DRC) for a specific aspect. Let's consider an 8-layer design where L3 is designated as the signal layer. This layer has multiple DRC checks such as via-to-via, line-to-line, via-to-line, and vice versa.
    However, I want to enable or make visible only the via-to-via error class, while the other error classes should remain hidden.
    Additionally, how can I differentiate between the DRC colors for each type of error on the same layer?
    Kindly notify me if you require further details.
    Ram.
  • VVRD
    +1 VVRD over 2 years ago in reply to Ram1234
