  3. drc check on specific layers only
  • State Suggested Answer
  • Answers 2
  • Views 6975
masamasa
masamasa over 2 years ago
hello
is there a way to run the drc check only on a particular layer?
most often, it takes a long time to run the drc check for the whole desgin so i would like to run the drc check only on one layer for instance.
the color visibility controls only drc errors to display on particlar layers.
  • SandeepVarrier
    SandeepVarrier over 2 years ago +1 suggested
    Please Try the new DRC Browser from the menu Tools> DRC Browser, here you can view DRC Errors domain wise and Constraint wise. Here you can also filter DRC's layer wise Under DRC Subclass
  • SandeepVarrier
    0 SandeepVarrier over 2 years ago
  • SandeepVarrier
    0 SandeepVarrier over 2 years ago in reply to SandeepVarrier
  • masamasa
    0 masamasa over 2 years ago in reply to SandeepVarrier
    thank u for ur response.
    my design does not show the spacing on the drc browser.
    how do i need to set it up?
    regards
    masa
