  3. 3D models not visible in the MCAD tool after exporting from...
  • State Suggested Answer
  • Answers 1
  • Views 7858
3D models not visible in the MCAD tool after exporting from the PCB editor tool
RohitRohan
RohitRohan over 2 years ago
Dear community,
I had created a PCB board and mapped all the step models with 3D models and i can see all the 3D models in the 3D canvas window, but when i export the step file of the PCB board and import to MCAD tool, i am seeing only plane board without any 3D models, i have provided the step path in the User preference paths.
  • RohitRohan
    RohitRohan over 2 years ago in reply to RohitRohan +3 suggested
    Hai, Currently i got solution for that, i had to provide the Step path for all the Step files in the allegro tool and match the step protocol to the MCAD tool. I also came to know that we can export…
  • Ulf K
    Ulf K over 2 years ago +1
    I encountered the same problem some time ago. It was caused by the library paths to the STEP-files and their mapping was not correctly defined in my user preferences.
  • Ulf K
    0 Ulf K over 2 years ago
  • VVRD
    0 VVRD over 2 years ago
    what MCAD tool you're using?
  • RohitRohan
    0 RohitRohan over 2 years ago in reply to VVRD
    I am using the Solid works for MCAD
  • RohitRohan
    0 RohitRohan over 2 years ago in reply to RohitRohan
    Hai,
    I also came to know that we can export the STL file from the Allegro tool, what is the difference between the step file and STL file, which is better to export to MCAD tool.
    • Vote Up +3 Vote Down
