  3. Exporting Libraries
  • State Suggested Answer
  • Replies 10
  • Answers 3
  • Subscribers 166
  • Views 10705
Exporting Libraries
Tahakhan
Tahakhan over 2 years ago
When I Export libraries using "dlib" it takes a lot of time for some Board files and in the end it won't even generate after waiting for like 8hours. Is there any way to speed up the process?
Using allegro 17.2
I tried 17.4 as shown below but it got stuck on 99% after 3minutes. I assume it will remain stuck.
  • John T
    John T over 2 years ago in reply to Tahakhan +2 suggested
    An Xnet (Extended net) is a connection of two nets that are electrically connected through a passive discrete component, typically a resistor. If you have these in your design you will find them listed…
  • DavidJHutchins
    DavidJHutchins over 1 year ago in reply to John T +2
    To refine to 'John T's posting: Please also try saving this brd file to a simple directory on the LOCAL hard drive; I have seen issues due to latency issues with network file shares...
  • Gajendiran
    Gajendiran over 1 year ago in reply to John T +2
    Thanks john for your reply! I have updated cadence software from 24.10.1 to 24.10.5 (hot fix) and that solved my problem now able to export the lib without any issues and quicker. Thanks,
  • Gajendiran
    0 Gajendiran over 1 year ago in reply to John T
    Using allegro 17.2
    Hi John T,
    I'm also seeing the same issue with Allegro-X. Could you please let me know what the fix is? I tried all the above, but I'm still experiencing the same issue.
  • John T
    0 John T over 1 year ago in reply to Gajendiran
    Hi Gajendiran, there was nothing conclusive because the file could not be shared this user. I see you have opened a case with our Cadence support team. My colleague will assist you with this issue and provide you with a temporary ftp link  to transfer this data securely.
  • DavidJHutchins
    0 DavidJHutchins over 1 year ago in reply to John T
    • Vote Up +2 Vote Down
  • Gajendiran
  • DW202503105936
    0 DW202503105936 1 month ago
    I use 24.1 - On my database it was an issue with the text block sizes, I compacted them, and removed the ones which were over block 64, and the issue was resolved.
