  3. Exporting Libraries
  • State Suggested Answer
  • Replies 10
  • Answers 3
  • Subscribers 166
  • Views 10704
Exporting Libraries
Tahakhan
Tahakhan over 2 years ago
When I Export libraries using "dlib" it takes a lot of time for some Board files and in the end it won't even generate after waiting for like 8hours. Is there any way to speed up the process?
Using allegro 17.2
I tried 17.4 as shown below but it got stuck on 99% after 3minutes. I assume it will remain stuck.
  • John T
    John T over 2 years ago in reply to Tahakhan +2 suggested
    An Xnet (Extended net) is a connection of two nets that are electrically connected through a passive discrete component, typically a resistor. If you have these in your design you will find them listed…
  • DavidJHutchins
    DavidJHutchins over 1 year ago in reply to John T +2
    To refine to 'John T's posting: Please also try saving this brd file to a simple directory on the LOCAL hard drive; I have seen issues due to latency issues with network file shares...
  • Gajendiran
    Gajendiran over 1 year ago in reply to John T +2
    Thanks john for your reply! I have updated cadence software from 24.10.1 to 24.10.5 (hot fix) and that solved my problem now able to export the lib without any issues and quicker. Thanks,
  • John T
    0 John T over 2 years ago
    Hi Tahakhan, I would try running the dbdoctor Database Check on your design firstly. I would also consider purging all unused padstacks. You will find this in the Padstack Modify options menu tab. Here there is a Purge button to purge all. Please also consider checking the option “No library dependencies” during export.
  • Tahakhan
    0 Tahakhan over 2 years ago in reply to John T
    I have tried Dbdoctor without check on Regenerate Xnets. What does this term Regenerate Xnets means? The steps you mentioned above I normally follow them in my design but still this problem persists. It's maybe due to design complexity as layer count is above 70 but still there must be a solution for it.
  • John T
    0 John T over 2 years ago in reply to Tahakhan
    An Xnet (Extended net) is a connection of two nets that are electrically connected through a passive discrete component, typically a resistor. If you have these in your design you will find them listed along with nets in Constraint Manager.   Xnets are required in electrical constraint applications to constrain a logical net in length or time from a driver to receiver through the discrete part. Nets and Xnets apply to the Electrical, Physical, and Spacing domains. You can constrain a net or Xnet by either referencing a CSet or setting overrides directly on the net or Xnet object. This Regenerate button forces the editor to regenerate all Xnets and differential pairs in the design database.
    If you are willing to share your design with us to investigate, I will contact you directly to exchange.
    • Vote Up +2 Vote Down
  • John T
    0 John T over 2 years ago in reply to John T
    I sent you a friendship request message on forums with my email address. Please respond when possible.
  • Tahakhan
    Thanks for the information and please check your inbox I have responded.
