  3. Extract 3D step file name from a Board file
  • State Suggested Answer
  • Answers 1
  • Views 6124
madhesh
madhesh over 2 years ago
we inquire about the possibility of bulk extracting step file names associated with their respective footprints.
and we currently working on a project that requires a comprehensive list of all step file names used in our footprints. Manually extracting this information would be time-consuming and prone to errors.
  • steve
    steve over 2 years ago +2 suggested
    If you open the 3d canvas and look at the 3d Mapper tab there is an Export button. This writes a file out that should contain what you require for each symbol in the design. It is based on a board design…
  • steve
    0 steve over 2 years ago
    If you open the 3d canvas and look at the 3d Mapper tab there is an Export button. This writes a file out that should contain what you require for each symbol in the design. It is based on a board design though rather than a library of footprints.
    • Vote Up +2 Vote Down
