  3. odb++ import
  • State Suggested Answer
  • Answers 1
  • Subscribers 166
  • Views 16534
odb++ import
masamasa
masamasa over 2 years ago
hello
is there a way to import odb++ files into the pcb editor?
the help menu has the description of the valor translation.
do i need the valor translation to import odb++ files?
regards
masa
  • steve
    steve over 2 years ago +1
    Not ODB++ but you can import IPC2581 which may be a better method. You can also look at CAM350 (Downstream Tech) which will import ODB++, you can then export a PADS Ascii file which Allegro will import…
  • steve
    0 steve over 2 years ago
    Not ODB++ but you can import IPC2581 which may be a better method. You can also look at CAM350 (Downstream Tech) which will import ODB++, you can then export a PADS Ascii file which Allegro will import.
  • masamasa
    0 masamasa over 2 years ago in reply to steve
    thank u, steve.
    i will look into this route.
  • VVRD
    0 VVRD over 2 years ago
    Yes, you need ODB++ inside installation to import ODB++ files. Please see below article,
    Article (11656580) Title: What do I need to export ODB++ and how do I download ODB++ Inside for Cadence Allegro and ODB++ Viewer?
    URL: https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od0000000nbsIEAQ
    add env variable as shown below,
  • DavidJHutchins
    0 DavidJHutchins over 2 years ago in reply to VVRD
    The latest 23.1 hotfix includes a new command to import ODB++ data, below is the top few lines from it's documentation:
    odbpp in
    The odbpp in command imports an OBD++ archive into the layout editor. The following archive formats are supported: .tgz, .tar, .tar.gz, .tar.z, .zip.
    Available in Allegro X Advanced Package Designer. To access this command in PCB Editor, enable odbpp_import_utility in the User Preferences dialog box.
  • masamasa
    0 masamasa over 2 years ago in reply to DavidJHutchins
    thank u for ur response, david.
    unfortunately i still have 17.4 so i would have to wait for my company to upgrade it to 23.1.
     it is good information though, thank u.
