  3. gds import/epxport
  • State Verified Answer
  • Subscribers 159
  • Views 4028
gds import/epxport
masamasa
masamasa over 1 year ago
hello
is there a way to import and export gds files to the pcb editor?
regards
masa
  • DavidJHutchins
    +1 DavidJHutchins over 1 year ago
    use 'stream out' to write gds files
    use 'load stream' to import gds files
  • masamasa
    0 masamasa over 1 year ago in reply to DavidJHutchins
    thank u, david, for ur reply.
    i tried to import a gds file, but it does not allow me to select all layers from the gds file.
    how can i import all layers of a gds file into the pcb editor?
    regards
    masa
  • DavidJHutchins
    0 DavidJHutchins over 1 year ago in reply to masamasa
    It works correctly for me...
    My initial question is why don't you have class and subclass entries mapped for those 3 layers?
  • masamasa
    thank u, david for ur response as always.
    this is the first time i imported gds file so i know nothing about gds.
    this gds file was created by our customer so i do not know why there is subclass on the gds file.
    cadence told me that i need the latest hotfix to solve this.
    so i am trying to install the latest one.
  • DavidJHutchins
    I would recommend you take a simple board file & export a stream file, then import it back into new layers in the manufacturing class
    That is how I learned to use these commands
