  3. Allegro – Tip of the week: Forcing the name of an XNet
  • Subscribers 163
  • Views 6192
JuanCR
JuanCR over 2 years ago
When grouping nets to create an XNet, there is an internal algorithm that determines the name of extended nets(XNET) automatically. This algorithm uses the following criteria (in a hierarchical order):
  1. A net that is higher in the design hierarchy is selected.
  1. If both nets have zero driver pins, the one with non-zero receiver pins is selected.
  1. If both nets have zero driver pins and non-zero receiver pins, the one with the least number of receiver pins is selected.
  1. If one has zero driver pins and the other has non-zero receiver pins, the one with zero driver pins is selected.
  1. If no net is selected yet, the one that comes first, lexicographically, is selected.
 However, there is a way to bypass this algorithm and force the name of the XNet. If you attach the CDS_XNET_NAME property to a net, you will force this net name to the XNet level.
Configure it as follows:
In this example, after following these steps, you will ensure that the XNet name is N852308.
Have you used XNet or net properties that you found particularly useful for a design? Share your experience with the community and let us learn from each other.
