  3. Snapping functions
  • State Suggested Answer
  • Answers 1
  • Views 8536
Snapping functions
JuriV
JuriV over 2 years ago
hi everybody,
I am using Orcad PCB designer 23.1.
If the measure or dimension function with snapping is used that works some times not correctly. E.g. if Measure -> Snap pick to Pad Edge Midpoint is checked the cursor snapes to Pin center. Although Persistance Snap is OFF, the next snapping is allways the last one, in this case Pin.
Everybody knows this problem.
Thank you
JuriV
  • VVRD
    VVRD over 2 years ago +1 suggested
    The reason for not being able to measure from Pad Edge to Pad Edge is that the Find filter has Pin selected, and this snaps the pick to the center of the Pin. To measure from Pad Edge to Pad Edge, use…
  • VVRD
    0 VVRD over 2 years ago
    To measure from Pad Edge to Pad Edge, use the following steps:
    1. Navigate to the menu Setup > Application mode > General Edit or Placement Edit
    2. Select Display > Measure from the menu.
    3. In the Find filter disable all object selections (All Off).
    4. Place the cursor at the point where you wish to measure (zoomed in to the point will give you better accuracy) and click right mouse button, RMB > Snap pick to  > Pad Edge Midpoint.
    This will allow you to select the pad edge as desired.
  • JuriV
    0 JuriV over 2 years ago in reply to VVRD
    Hi VVRD,
    thanks, it helps.
    Best regards
