  3. Place Replicate Apply Force Manual Mapping
  • State Suggested Answer
  • Answers 1
  • Subscribers 166
  • Views 9253
TpermanLuma
TpermanLuma over 2 years ago
I am trying to use the Place Replicate apply functionality to replicate circuitry. Unfortunately the automatic mapping which Allegro has worked out isn't quite right.
If components were unmatched a pop-up window would allow the mapping to be set manually to the correct values. Is it possible to force this pop-up, or to change the mapping after the fact?
  • techiecs
    techiecs over 2 years ago +1 suggested
    Normally, the component mapping dialog box is only displayed if there is some ambiguity in component assignment and your inputs are needed. You can set user preference variable 'plc_rep_show_matching_dialog…
  • DavidJHutchins
    0 DavidJHutchins over 1 year ago in reply to evseshu
    it works for me using 'allegro 23.1 S003 Windows SPB 64-bit Edition' with the 'Allegro PCB Designer' license.
    I used 'Tools>create Module...'
