  3. Place Replicate Apply Force Manual Mapping
  • State Suggested Answer
  • Answers 1
  • Subscribers 166
  • Views 9248
TpermanLuma
TpermanLuma over 2 years ago
I am trying to use the Place Replicate apply functionality to replicate circuitry. Unfortunately the automatic mapping which Allegro has worked out isn't quite right.
If components were unmatched a pop-up window would allow the mapping to be set manually to the correct values. Is it possible to force this pop-up, or to change the mapping after the fact?
  • techiecs
    techiecs over 2 years ago +1 suggested
    Normally, the component mapping dialog box is only displayed if there is some ambiguity in component assignment and your inputs are needed. You can set user preference variable 'plc_rep_show_matching_dialog…
  • Jim OMahony
    0 Jim OMahony over 2 years ago
    You might try selecting an extra component, maybe something mechanical to be obvious. That creates an error which brings up your form. You just ignore the extra comp when you place the replicate block.
  • TpermanLuma
    0 TpermanLuma over 2 years ago in reply to Jim OMahony
    I tried selecting an additional component when running the "Apply" step and Allegro just seemed to ignore it. Or are you suggesting selecting an extra component when defining the module?
  • techiecs
    0 techiecs over 2 years ago
    You can set user preference variable 'plc_rep_show_matching_dialog' to always display the Place Replicate Unmatched Component Interface dialog box to customize the mapping of all the components between the seed circuit and the replicated circuit. You can set this variable by going to Setup>User Preferences>Placement>General category.
  • TpermanLuma
    0 TpermanLuma over 1 year ago in reply to techiecs
    techiecs Is "plc_rep_show_matching_dialog" a variable only available in newer versions of Allegro? I am using v22.1 currently and cannot see this variable in the Placement->General section.
  • evseshu
    0 evseshu over 1 year ago in reply to techiecs
    I unable to create placement replicate module in Cadence23.1 but in 16.6 it is availble please help me where placement replicate available in this software thank you
