  3. define via structure path
  • State Verified Answer
  • Views 7134
zpofrp
zpofrp over 2 years ago
Hi help me,
I want to import via strcutre to new design,the via structure is created in old design.
but i dont know to define the via structure lib or path.
the via structure file is .exml, i dont find it in the user oreferences editor>paths>library.
so can you help me
thanks
  • mahimag
    mahimag over 2 years ago +1 verified
    Hello zpofrp , Allegro PCB Editor reads the padpath variable to find the via structures. Padpath can be set in Allegro using Setup > User Preferences and selecting the Paths > Library tab.
  • mahimag
    +1 mahimag over 2 years ago
    Hello zpofrp, Allegro PCB Editor reads the padpath variable to find the via structures. Padpath can be set in Allegro using Setup > User Preferences and selecting the Paths > Library tab.
