  3. OrCad X standard vs OrCad X Professional
  • State Suggested Answer
  • Answers 1
  • Subscribers 167
  • Views 12963
drobny
drobny over 2 years ago
Does anyone know what the differences are in available software features and capabilities between OrCad X Standard and OrCad X Professional licenses?
  • steve
    steve over 2 years ago in reply to drobny +1 suggested
    So OrCAD X Std doesn't have dynamic phase in PCB Editor - only static phase unless you use OrCAD X Presto Std. Keep an eye on the Parallel Systems Matrix - we are in the process of trying to add a Presto…
  • digital1
    0 digital1 over 2 years ago
    Please see this matrix from Parallel systems in the UK which lists the differences between orcad standard orcad professional and allegro
    The differences will be found at the bottom of the matrix
  • gvellet
    0 gvellet over 2 years ago in reply to digital1
    The matrix has been updated with Orcad X name on it but it is partly wrong. The licence "Orcad X Pro" has more features taken from Allegro than "Orcad Pro"  For instance, with Orcad X pro the constraint manager now includes electrical rules for "VIA" and "return path". These were exclusive features to Allegro high speed package, now ordinary people (like us) can avail to it.
    But my feeling is that Cadence is still in progress of documenting properly all the changes in Orcad X pro versus Orcad pro. There is also a discrepency of features enabled between Orcad PCB editor and Orcad Presto. Presently if you want to use the new high speed feature of constraint manager, they are only reachable thru Orcad Presto. Even with an Orcad X pro license, Orcad PCB editor behave like with an Orcad pro license. It is a bit weird. I dont know if Cadence plan is to keep both PCB editor, or to gradually discontinue Orcad PCB Editor. Many questions are left to be answered...
  • drobny
    0 drobny over 2 years ago
    I found a comparison on the website of the Danish distributor, but it doesn't seem to me that there is a rule available for dynamic phase control in OrCad X Standard.
    https://www.nordcad.eu/products-services/ecad/pcb-design/orcad-features/
    Why is the licensing so convoluted, and the Cadence doesn't officially provide exact differences?"
  • steve
    0 steve over 2 years ago in reply to drobny
    So OrCAD X Std doesn't have dynamic phase in PCB Editor - only static phase unless you use OrCAD X Presto Std. Keep an eye on the Parallel Systems Matrix - we are in the process of trying to add a Presto version. It is currently valid for PCB Editor.
    Edit - try this: OrCADX - Parallel Systems (parallel-systems.co.uk) at the bottom is a comparison list that should help.
