  3. shape parameter
  • State Suggested Answer
  • Replies 7
  • Answers 1
  • Views 9074
shape parameter
masamasa
masamasa over 2 years ago
hello:
is there a way to access the shape parameters in an easier way?
after selecting a shape, it does not show the parameters on the right botton menu.
so i usually select a shape from the menu and the right botton menu shows the parameters.
i have hundreds of shapes somtimes so i would like to find a way to access the shape parameters in a quicker way.
  • VVRD
    VVRD over 2 years ago in reply to masamasa +1
    Hi, Try this, 1. Type funckey s pop shape param in command window. It will assign key "s" to parameter window. 2. Select shape and type s and enter in command window, it should work Thank you…
  • masamasa
    0 masamasa over 2 years ago in reply to VVRD
    thank u for ur response.
    mine is 17.4-2019 S039
  • Elecguy
    0 Elecguy over 1 year ago in reply to masamasa
    masamasa  ... the funckey line above is wrong. Try this:
    funckey s shape param
    But make sure you're in Shape Edit Mode
