  3. shape parameter
  • State Suggested Answer
  • Replies 7
  • Answers 1
  • Views 9073
shape parameter
masamasa
masamasa over 2 years ago
hello:
is there a way to access the shape parameters in an easier way?
after selecting a shape, it does not show the parameters on the right botton menu.
so i usually select a shape from the menu and the right botton menu shows the parameters.
i have hundreds of shapes somtimes so i would like to find a way to access the shape parameters in a quicker way.
  • VVRD
    VVRD over 2 years ago in reply to masamasa +1
    Hi, Try this, 1. Type funckey s pop shape param in command window. It will assign key "s" to parameter window. 2. Select shape and type s and enter in command window, it should work Thank you…
  • DavidJHutchins
    0 DavidJHutchins over 2 years ago
    my only suggestion would be to create a funckey similar to the following:
    funckey slp shape layer param
  • masamasa
    0 masamasa over 2 years ago in reply to DavidJHutchins
    thank u for ur response, david.
    i have tried the following funckey but nothing is poping up.
    funckey F12 "pop shape param"
  • VVRD
    +1 VVRD over 2 years ago in reply to masamasa
    Try this,
    Thank you.
  • masamasa
    0 masamasa over 2 years ago in reply to VVRD
    hello
    thank u for ur response.
    unfortunately it does not work.
    even if i select a shape, it says no shape selected.
  • VVRD
    0 VVRD over 2 years ago in reply to masamasa
    May I know what version are you using? I tried it in latest 23.1 version and it worked
