  3. DFA circle will not appear while placing components in allegro...
  • State Suggested Answer
  • Answers 1
  • Subscribers 166
  • Views 9751
DFA circle will not appear while placing components in allegro PCB Artist ?
Kabaleeswaran
Kabaleeswaran over 2 years ago
Hi Team,
I am using Allegro PCB artist 23.1 version. I did DFA in constraint manager but i could not find the spreadsheet table for  enable the DRC ON or  DRC Mode to 'Off'. is that feature is available in PCB artist 23.1 ?
  • Robert Finley
    0 Robert Finley over 2 years ago
    I don't get to use this very often, and I'm idle at the moment.   I found out the legacy DFA table is rolled into constraints manager.
    But, the old tricks to get DFA assembly to work are dormant.
    If you generate the Report called Design for Assembly Summary Report, does it match what I have?
    For years, this was available with Allegro licenses.   I was told they've added this functionality to the Orcad license level starting with 22.x.
    I own Allegro ALGX03, Allegro Designer.
