  3. DFA circle will not appear while placing components in allegro...
  • State Suggested Answer
  • Answers 1
  • Subscribers 166
  • Views 9750
DFA circle will not appear while placing components in allegro PCB Artist ?
Kabaleeswaran
Kabaleeswaran over 2 years ago
Hi Team,
I am using Allegro PCB artist 23.1 version. I did DFA in constraint manager but i could not find the spreadsheet table for  enable the DRC ON or  DRC Mode to 'Off'. is that feature is available in PCB artist 23.1 ?
  • DavidJHutchins
    0 DavidJHutchins over 2 years ago
    I think you need to open Setup>Constraints>Modes...
    Then select Design For Assembly>PkgToPkg Spacing
    Then enable Package to package spacing
  • Kabaleeswaran
    0 Kabaleeswaran over 2 years ago in reply to DavidJHutchins
    Hi David,
    i tried your steps
    DFA also opened in Constraint Manager. i set
    i could not any circle in this placement, can you help on this
    Kabaleeswaran
  • DavidJHutchins
    0 DavidJHutchins over 2 years ago in reply to Kabaleeswaran
    OK, I have 2 different licenses:
    it works for me using 'Allegro PCB Designer'
    it does not work for me using 'OrCAD PCB Designer Standard'
    However I don't know what features are included with your Allegro PCB artist license, sorry Disappointed
  • Jeff H
    0 Jeff H over 2 years ago in reply to Kabaleeswaran
    Looks like you have it set up in the constraint section, but have you enabled it in the Design section below?
  • Kabaleeswaran
    0 Kabaleeswaran over 2 years ago in reply to Jeff H
    sorry for the delay response.. i tried one more time in Allegro X artist i could see the DRC marking but while moving the component i could see circular DRC marking
    even i enabled
    still i could get  white Circular DRC in real time placement . is any tool limitation.
