  3. How to get the list of unconnected pin pairs in the DRC...
  • State Suggested Answer
  • Answers 1
  • Views 6713
How to get the list of unconnected pin pairs in the DRC status
RohitRohan
RohitRohan over 2 years ago
Hai community,
How to get the list of unconnected pin pairs in the DRC status, i can get the list in the quick reports >> unconnected pin pairs or in the DRC status window if we click on the unrouted connections under the Symbols and Nets, but is there away to get the same report in the DRCs (DRC Report)
  • John T
    John T over 2 years ago +1 suggested
    Hi Rohit, have you tried the find by query functionality? Here you can specify unconnected pins. You can also filter by differential pairs or other filters as you like using the AND functionality. Please…
  • John T
    0 John T over 2 years ago
    Hi Rohit, have you tried the find by query  functionality? Here you can specify unconnected pins. You can also filter by differential pairs or other filters as you like using the AND functionality. Please see the snapshot below where I set the unconnected pins >1. To do this just double click the word in the filter and you will be presented with filter value options:
    In general unconnected lines are not considered for drc flags as we use rat-lines as our visual reference for that. Therefore they are not present in the DRC report. We typically use the Display > Status of the design to check for any unrouted nets which displays the connected quantity, the total quantity and the percentage of unrouted connections and nets. Hopefully the find by query meets your needs which also enables you to scroll and zoom to each entry.
