  3. Dynamic copper not voiding around vias and through-hole...
  • State Verified Answer
  • Views 8470
Dynamic copper not voiding around vias and through-holes
dsizzle83
dsizzle83 over 2 years ago
I am running into issues updating a layout.  I am using Orcad PCB Designer 22.1 Standard license.
I am not able to generate dynamic shapes with proper voids around vias and through-holes.  On some layers, it will autofill the voids and others it won't.
dbdoctor gives the following errors:
(    DBDOCTOR                                                         )
(    Drawing          : 41-00058-01_REV02.brd                         )
(    Software Version : 22.1S005                                      )
(    Date/Time        : Mon Apr 15 13:43:56 2024                      )
WARNING: in PAD STACK padstack name = T_N20_30
  WARNING(SPMHDB-46): Illegal null pad.
  No ANTI pad defined on layer L2_GND.
  This could result in the wrong clearance on negative layer.
  No ANTI pad defined on layer L4_GND.
  No ANTI pad defined on layer L5_SIG_H.
  No ANTI pad defined on layer L6_GND.
  No ANTI pad defined on layer L7_VCC.
  No ANTI pad defined on layer L8_VCC.
  No ANTI pad defined on layer L9_GND.
  No ANTI pad defined on layer L10_SIG_H.
  No ANTI pad defined on layer L11_GND.
  No ANTI pad defined on layer L13_GND.
WARNING: in PAD STACK padstack name = EX67Y67D47P
WARNING: The following vias/pins have connections on positive layers
         using a padstack without a REGULAR pad defined. Your
         artwork output may not be correct.
  Pin/Via         Padstack             Layer                 Location
  D23.8           5CT_NULL             BOTTOM              (4040.00 -106.00)
  D17.8           5CT_NULL             BOTTOM              (4195.00 -101.00)
  D16.8           5CT_NULL             BOTTOM              (4345.00 -101.00)
  D24.8           5CT_NULL             BOTTOM              (2790.00 -106.00)
  D18.8           5CT_NULL             BOTTOM              (2945.00 -101.00)
  D15.8           5CT_NULL             BOTTOM              (3095.00 -101.00)
  D5.8            5CT_NULL             BOTTOM              (1695.00 -101.00)
  D4.8            5CT_NULL             BOTTOM              (1845.00 -101.00)
  D11.8           5CT_NULL             BOTTOM              (1540.00 -106.00)
  D12.8           5CT_NULL             BOTTOM              (290.00 -106.00)
  D3.8            5CT_NULL             BOTTOM              (595.00 -101.00)
  D6.8            5CT_NULL             BOTTOM              (445.00 -101.00)
Regenerating DRC
  Original DRC errors:   855
  Updated DRC errors:    855
  DRC elapsed time:      00:00:01
44 warnings, 0 errors detected, 0 errors  fixed.
  • techiecs
    techiecs over 2 years ago +2
    This warning might be seen due to the presence of unused padstacks in the design. If you go to Tools>Padstack>Modify Design Padstack and select all the padstacks seen in the warning from the Options panel…
  • avant
    avant over 2 years ago +2
    If the layers are defined as negative, change them to positive. This is found in the cross section.
  • dsizzle83
    dsizzle83 over 2 years ago in reply to techiecs +1 verified
    Thank you for your reply. I'm still not sure the root cause, but I found a workaround. My original design was done by a contractor using 17.2. I modified the cross-section on the original design and exported…
  • techiecs
    0 techiecs over 2 years ago
    If you go to Tools>Padstack>Modify Design Padstack and select all the padstacks seen in the warning from the Options panel that appear on the right side of the tool. Select Purge>All here to purge the selected unused padstacks in the design that has an illegal null pad.
    Try these steps to get away with the warnings/errors.
    • Vote Up +2 Vote Down
  • avant
    0 avant over 2 years ago
  • dsizzle83
    +1 dsizzle83 over 2 years ago in reply to techiecs
    Thank you for your reply.  I'm still not sure the root cause, but I found a workaround.  My original design was done by a contractor using 17.2.  I modified the cross-section on the original design and exported the constraints to the new design.  After importing the constraints, I was able to update the shapes and get proper voids around vias.
  • dsizzle83
    0 dsizzle83 over 2 years ago in reply to avant
    Thank you for your reply.  All the layers are positive.  I believe the issue is from my constraints.  Once I imported a 14-layer constraint file and re-poured, the vias are properly voided.
