  3. stacked via location
  • State Suggested Answer
  • Answers 1
  • Views 7739
masamasa
masamasa over 2 years ago
hello
is there a way to find where stacked padstacks/vias are located?
i have a 6 layer design with L1 thru L6.
i would like to find the locations of stacked vias such as vias L1 thru L6, L2 thru L5, and L4 thru L6.
This is designed by our customer and our customer assigned each padstack layer by layer like L1 thru L2, L2 thru L3 and so on.
regards
masa
  • SaiPavanl
    SaiPavanl over 2 years ago +1 suggested
    You can use below SKILL code to get list of stacked vias and coordinates ;get all stacked vias in design axlCmdRegister("get stackedvia" `getStackedVias) (procedure getStackedVias() (let (viaListAtLoc…
  • SaiPavanl
    0 SaiPavanl over 2 years ago
    (let (viaListAtLoc curViaNameList allVias curLoc viaList)
    ;get all Vias in design
    viaLocMap=makeTable("ViaMapLocTable" nil)
    axlSetFindFilter(?enabled list( "noall" "vias") ?onButtons list( "noall" "vias"))
    axlAddSelectAll()
    allVias = axlGetSelSet()
    ;Make a table for Via with location as key
    (foreach curVia allVias
    ;printf("curVia is %s loc %L\n" curVia->name curVia->xy)
    curLoc=curVia->xy
    viaListAtLoc=viaLocMap[curLoc]
    (if viaLocMap[curLoc] then
    viaListAtLoc=cons(curVia viaListAtLoc )
    viaLocMap[curLoc]=viaListAtLoc
    else
    viaLocMap[curLoc]=list(curVia)
    ;print List of Vias
    printf("Stacked vias \n")
    (foreach key viaLocMap
    viaList=viaLocMap[key]
    curViaNameList=list()
    (if length(viaList) > 1 then
    (foreach curVia viaList
    curViaNameList = cons( curVia->name curViaNameList)
    ;printf("\tvia %s \n" curVia->name )
    printf("%L : %L\n" key curViaNameList)
    (axlShell "done")
    );let
    );procedure
  • avant
    0 avant over 2 years ago
    if you want to visually see them on the board, turn on "Drill Labels" in the design parameters.
  • masamasa
    0 masamasa over 2 years ago in reply to avant
    thank u for your response.
    my design has over 1 million vias so i can not visually check drill labels one by one unfortunately.
  • Hoangkhoipcb
    0 Hoangkhoipcb over 2 years ago in reply to masamasa
    Hi masamasa!
    You can refer my code. My design has over 150 thousand vias. i apply rule via same location only, no same pad.
    HoangKhoi.
