  3. Allegro skill Symbols overlap
  • State Suggested Answer
  • Answers 1
  • Views 7008
ivy372
ivy372 over 2 years ago
Hi all,
I want to check symbol's place_bound overlap value.
The check rule is when the place_bound edge on edge is ok as below:
The axlGeoIsBoxOverlap result is only show the ⇒ t/nil
axlGeoIsBoxOverlap
axlGeolsBoxOverlap(
l_first_bbox
l_second_bbox
[t_orientation]
⇒ t/nil
How can I get the overlap value?
Thanks~
  • DavidJHutchins
    DavidJHutchins over 2 years ago +1 suggested
    Why don't you use Setup>Constraints>DFA Constraint Spreadsheet ???
  • DavidJHutchins
    0 DavidJHutchins over 2 years ago
  • DavidJHutchins
    I added some code to the original skill I provided to calculate the size of the overlap...
    procedure(Check_Overlap()
    let((Layers ShapeLayer Shapes Shape poly1 poly2 l_result bbox llx lly urx ury Dx Dy)
    (Layers = list("PLACE_BOUND_TOP" "PLACE_BOUND_BOTTOM"))
    foreach( Layer Layers
    (axlClearSelSet)
    (ShapeLayer = strcat("PACKAGE GEOMETRY/" Layer))
    axlVisibleDesign(nil)
    axlVisibleLayer(ShapeLayer t)
    axlSetFindFilter(?enabled list("noall" "shapes" ) ?onButtons list("noall" "shapes" ))
    (axlAddSelectAll)
    (Shapes = axlGetSelSet())
    (axlClearSelSet)
    (Shape = car(Shapes))
    (Shapes = cdr(Shapes))
    while( and(Shape listp(Shapes))
    foreach( Remaining Shapes
    ;axlMsgPut("Checking between %s and %s" Shape->parent->refdes Remaining->parent->refdes)
    when( axlGeoIsBoxOverlap(Shape->bBox Remaining->bBox)
    ;axlMsgPut("ERROR: Overlap between %s and %s" Shape->parent->refdes Remaining->parent->refdes)
    (poly1 = (axlPolyFromDB Shape))
    (poly2 = (axlPolyFromDB Remaining))
    (l_result = (axlPolyOperation poly1 poly2 'AND))
    if( null(l_result) then
    axlMsgPut(list axlPolyErrorGet())
    else
    foreach( poly l_result
    (bbox = (poly->bBox))
    (llx = caar(bbox))
    (lly = cadar(bbox))
    (urx = caadr(bbox))
    (ury = cadadr(bbox))
    (Dx = (urx - llx))
    (Dy = (ury - lly))
    if( Dx < Dy then
    axlMsgPut("ERROR: Overlap %f between %s and %s" Dx Shape->parent->refdes Remaining->parent->refdes)
    else
    axlMsgPut("ERROR: Overlap %f between %s and %s" Dy Shape->parent->refdes Remaining->parent->refdes)
    t
  • ivy372
    0 ivy372 over 2 years ago in reply to DavidJHutchins
    I will try it~
    Thanks Dave so much~
