  3. How to make Assy Ref Des follow Ref Des Silk
  • State Verified Answer
  • Replies 8
  • Answers 1
  • Subscribers 166
  • Views 9796
Sagetech
Sagetech over 2 years ago
Is there a way to set the Assy Ref Des to follow the Ref Des silk location and size? It seems there should be as it quickly gets old having to move the assy ref des to match the silk ref des location when there are hundreds of parts on a pcb.
  • DavidJHutchins
    DavidJHutchins over 2 years ago +1 suggested
    The skill code below should move the assy text to the silk text locations, however I am on vacation & don't have access to licenses to test it... procedure(silk2assy() let((refdes layer orient silk assy…
  • avant
    avant over 2 years ago in reply to Sagetech +1 verified
    I plot setup, You can specify to use non-vectorized text (windows fonts) in the Windows tab. This will make the PDF searchable. I use Arial 90% height and 75% width.
  • avant
    +1 avant over 2 years ago in reply to Sagetech
  • Sagetech
    0 Sagetech over 2 years ago in reply to avant
    I will try that - thank you
  • Sagetech
    0 Sagetech over 2 years ago in reply to Sagetech
    Tried it, works well, thank you!
