  3. How to make Assy Ref Des follow Ref Des Silk
  • State Verified Answer
  • Replies 8
  • Answers 1
  • Subscribers 166
  • Views 9795
Sagetech
Sagetech over 2 years ago
Is there a way to set the Assy Ref Des to follow the Ref Des silk location and size? It seems there should be as it quickly gets old having to move the assy ref des to match the silk ref des location when there are hundreds of parts on a pcb.
  • DavidJHutchins
    DavidJHutchins over 2 years ago +1 suggested
    The skill code below should move the assy text to the silk text locations, however I am on vacation & don't have access to licenses to test it... procedure(silk2assy() let((refdes layer orient silk assy…
  • avant
    avant over 2 years ago in reply to Sagetech +1 verified
    I plot setup, You can specify to use non-vectorized text (windows fonts) in the Windows tab. This will make the PDF searchable. I use Arial 90% height and 75% width.
  • DavidJHutchins
    0 DavidJHutchins over 2 years ago
    let((refdes layer orient silk assy Dx Dy)
    foreach( symbol axlDBGetDesign()->symbols
    if( (symbol->definition->type == "PACKAGE" || symbol->definition->type == "MECHANICAL") then
    if( !symbol->refdes || nindex(symbol->refdes,"*") then
    (refdes = nil)
    else
    (refdes = symbol->refdes)
    if( symbol->component && refdes then
    if((((symbol->prop)->FIXED) == t)||((((symbol->component)->prop)->FIXED) == t) then
    axlMsgPut("skipping FIXED symbol %s" refdes)
    else
    (assy = nil)
    (silk = nil)
    foreach(Child symbol->children
    (layer = (Child->layer))
    if(((Child->objType) == "text") then
    if((symbol->isMirrored) then
    if((layer == "REF DES/SILKSCREEN_BOTTOM") then
    (silk = Child)
    (orient = axlTextOrientationCopy(Child))
    if((layer == "REF DES/ASSEMBLY_BOTTOM") then
    (assy = Child)
    else
    if((layer == "REF DES/SILKSCREEN_TOP") then
    (silk = Child)
    if((layer == "REF DES/ASSEMBLY_TOP") then
    (assy = Child)
    when(silk && assy
    axlTextOrientationCopy(assy orient)
    (Dx = xCoord(silk->xy) - xCoord(assy->xy))
    (Dy = yCoord(silk->xy) - yCoord(assy->xy))
    axlTransformObject(assy ?move list(Dx Dy))
    axlCmdRegister("silk2assy" 'silk2assy)
  • Sagetech
    0 Sagetech over 2 years ago in reply to DavidJHutchins
    Thank you for the reply. I feel stupid - what do I do with this / how do I use it?
  • DavidJHutchins
    0 DavidJHutchins over 2 years ago in reply to Sagetech
    Save the code into a file named 'silk2assy.il'
    Then in Allegro issue the command 'skill load "silk2assy.il"
    Then run the new command 'silk2assy'
  • jc teyssier
    0 jc teyssier over 2 years ago
    Why do you not use use silkscreen Ref Des instead of assembly one while generating your assembly drawing? The is the easier solution in this case.
  • Sagetech
    0 Sagetech over 2 years ago in reply to jc teyssier
    Typically that is what I do - and have been doing for years. But....... I had a request to create a searchable PDF of the silk including the pads.The Export PDF command will generate a searchable PDF. I had not used it before in my 30+ years of using Orcad.
    The export PDF command for the silk shows no pads and there is no option to add them. If I export the PDF for the top copper and suppress the traces I get the pads I need but it uses the assy layer for the pkg outlines and ref des. Thus I want the assy ref des to follow the location of the ref des on the silk layer.
    Printing to pdf does not allow for a searchable drawing whereas the Export PDF command does.
    Tom
