  3. (spmhdb-182): 'shape' object may not exist on class 'component...
  • State Suggested Answer
  • Answers 1
  • Subscribers 167
  • Views 5339
(spmhdb-182): 'shape' object may not exist on class 'component value'.
RohitRohan
RohitRohan over 2 years ago
Hai Community,
I am getting an error while copying a part of the PCB board, not all times but sometimes. When i select the part of the PCB and when i try to copy them using the copy command this is the error that i am facing "(spmhdb-182): 'shape' object may not exist on class 'component value'." Does any know the proper definition of this error and why i am getting them. Also there was no shapes in the part of the PCB when i was trying to copy them.
  • techiecs
    techiecs over 2 years ago +3 suggested
    It appears to be an issue in some older version. Can you please confirm which version and hotfix of Allegro are you using in which you see this error. Can you try copying a part of the PCB board in different…
  • B Bruekers
    B Bruekers over 1 year ago in reply to IMAN77 +2
    It has to do something with the active subclass. This happens since some early hotfix of 22.1. (S008) If you experience this issue: start to draw a cline on "TOP" (so setting active subclass to …
  • IMAN77
    0 IMAN77 over 1 year ago in reply to B Bruekers
    Thank you! It works!
