  3. Resolving DRC Errors for Blind Vias on BGA Pads in Alle...
  • State Suggested Answer
  • Answers 1
  • Views 7674
Resolving DRC Errors for Blind Vias on BGA Pads in Allegro
AB_1716552340330
AB_1716552340330 over 2 years ago
I used a 0.25mm pad size blind via on a BGA pad with a 0.25mm size. I set a 0.1mm B/B stagger clearance in the physical constraints, but I am still getting a DRC error: "Minimum blind/buried via stagger distance top constraint value: 0.1mm, actual value: 0mm." How can I solve this error in Allegro?
  • SaiPavanl
    SaiPavanl over 2 years ago +1 suggested
    I believe the location of blind Via and bga pad are overlapped exactly on the same location. In this case you add minimum BB Via Stagger value to 0. This will remove the Minimum blind/buried via stagger…
  • avant
    0 avant over 2 years ago
    Can you set "pad-to-pad connect" to allow via on pin? You could use a physical constraint region to allow it in a specific area only.
  • SaiPavanl
    0 SaiPavanl over 2 years ago
    I believe the location of blind Via and bga pad are overlapped exactly on the same location. In this case you add minimum BB Via Stagger value to 0. This will remove the Minimum blind/buried via stagger distance DRC
