  3. Allegro 23.1 sets "no Filled pads", but the drill holes...
  • State Suggested Answer
  • Answers 1
  • Views 2098
Allegro 23.1 sets "no Filled pads", but the drill holes are filled with display problems.
aarom
aarom over 2 years ago
The picture in question.
allegro 23.1 The display performance varies depending on the license level.
The system will automatically "load nv gpu plugin" after Allegro is turned on.
Causes a display with only drill holes filled.
Normal picture.
  • aarom
    aarom over 2 years ago +2 suggested
    Solution: You can only check it in Setup > User Preferences > display > opengl > disable_gpu. Mainly "Set to disable the GPU Plugin usage for Canvas rendering." In some older versions, "loading nv gpu…
  • aarom
    0 aarom over 2 years ago
    Solution:
    In some older versions, "loading nv gpu plugin." (starting GPU) will not be started.
    Turning off the independent display will affect the hardware display performance.
    The main license version in allegro 23.1 is "Allegro PCB Venture".
    I explained that one of the conditions is "loading nv gpu plugin" = NVIDIA independent graphics.
    In 17.2 and 17.4, the gpu warning window will appear first. This problem will not occur.
    This problem will occur in 22.1 and 23.1.
    • Vote Up +2 Vote Down
