  3. Problems with OrCAD X and livebom
  • Views 5527
Eruggeri
Eruggeri over 2 years ago
Dear all,
I'm just passed to new OrCAD X interface and I have some problems:
- How can I change the origin? In the old release 23.1 there was the command in the path Setup - Change drawing origin.
- In the export placement is disappeared the placement using "body center" . Is there a way to obtain the same result?
-In livedoc how can i turn off the display of Refdes-silkscreen top layer? It is not viewed in the layer Visibility list.
Thank you,
Emanuele
  • John T
    0 John T over 2 years ago
    There are several questions here. You may be more likely to get replies from the pcb community if you narrow your questions to a single issue. The origin setting is known and there are already several requests to include this capability in an upcoming release. I will check the other issues, thank you.
    Perhaps some users can also chime in if they have a similar experience or solutions.
