  3. Clines removal
  • State Suggested Answer
  • Replies 10
  • Answers 1
  • Subscribers 166
  • Views 10054
Clines removal
BaldEngineer
BaldEngineer over 2 years ago
Hi
What report should i run to find out these unconnected Clines?
Running Dangling lines report does not help as they are not connected to any pin. These Clines remained there after i deleted some portion of circuit in Capture.
  • VVRD
    VVRD over 2 years ago in reply to BaldEngineer +2 suggested
    This article might help you Article (20490359) Title: SKILL to find all dangling clines and dangling lines URL: support.cadence.com/.../ArticleAttachmentPortal
  • masamasa
    0 masamasa over 2 years ago
    this may help u.
    https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1O0V000009ETWqUAO&pageName=ArticleContent
  • BaldEngineer
    0 BaldEngineer over 2 years ago in reply to masamasa
    Thanks for response. I deleted the above clines and ran net loop report and this is what i am getting:
    Don't know if Skipped Net Summary as mentioned in the table is an issue here.
    At least don't know where to find these Nets and delete them as it is not pointing to any specific positions on the design.
    Update:
    As a matter of fact: I intentionally drew those clines again, just to check if it shows up in Net Loop report.
    But they don't show up in the report.
  • masamasa
    0 masamasa over 2 years ago in reply to BaldEngineer
    this may not work for u but there is a command called "package integrity."
    the command shows a menu that includes redundant clines
    regards
    masa
  • BaldEngineer
    I will give it a try.
    But where to find this Package Design Integrity Checks window.
  • Tyler
    0 Tyler over 2 years ago in reply to BaldEngineer
    The package integrity checks are only available in Allegro Package Designer. Are you in the PCB Editor tools? If so, that will unfortunately not be available to you.
