  3. another fillet question
  • State Suggested Answer
  • Replies 7
  • Answers 1
  • Views 7868
masamasa
masamasa over 2 years ago
hello
is there a way to find out the angle of existing fillets by clicking show elements or property on cline?
regards
masa
  • John T
    John T over 2 years ago in reply to John T +1 suggested
    A follow up check on this reveals that identical information can be displayed by pre-pressing "Display Element" which then enables the user to select fillets. The angle of the fillet line can therefore…
  • JuanCR
    0 JuanCR over 2 years ago
    Hi masamasa
    We're working on your query and will get back to you ASAP.
  • John T
    0 John T over 2 years ago
    Hi Masamasa, currently the only method I have to offer is to enable the selection of fillets using the following SKILL command:
    axlSetFindFilter(?enabled list("DYNTHEMALS" "SHAPES") ?onButtons list("SHAPES"))
    Once this is enabled, use the command axlSelect() now use a graphical selection to point select the fillet. The fillet gets selected and is highlighted. Some basic information can be displayed using show elements.
  • John T
    0 John T over 2 years ago in reply to John T
    The angle of the fillet line can therefore be reported within the Display Element command by nominating only "Other Segs" in the Find Filter.
  • masamasa
    0 masamasa over 2 years ago in reply to John T
    thank u for ur response.
    unfortunately mine does not show angles as shown below.
    i do not know how to program skill although i know how to use already-made skill programs.
    regards
    masa
  • Ethelones
    0 Ethelones over 2 years ago in reply to masamasa
    sadly my does not exhibit angles as shown here.
