  3. cline angle
  • State Verified Answer
  • Views 5962
cline angle
masamasa
masamasa over 2 years ago
hello
is there a way to add an angle to the line lock parameter?
currently off, 45 and 90 degrees are available but i would like to add 30 degree.
regards
masa
  • SaiPavanl
    SaiPavanl over 2 years ago +1 verified
    You can use the "Route Offset" option in the "Options" tab after going to Route Connect to achieve the desired angle of 30 degrees. Set a Line Lock at 45 degrees and specify a "Route Offset" of 15 degrees…
  • SaiPavanl
    +1 SaiPavanl over 2 years ago
    You can use the "Route Offset" option in the "Options" tab after going to Route Connect to achieve the desired angle of 30 degrees. Set a Line Lock at 45 degrees and specify a "Route Offset" of 15 degrees to route with the desired angle.
  • masamasa
    0 masamasa over 2 years ago in reply to SaiPavanl
    thank u for ur response.
    yes, it works
    regards
    masa
