  3. moving voids
  • State Verified Answer
  • Views 5535
moving voids
masamasa
masamasa over 2 years ago
hello
is there a way to move a void within a static shape?
i need to move hundreds of degassing voids a few microns on each of 28 layers.
regards
masa
  • John T
    John T over 2 years ago +1 verified
    Hi Masamasa, we can select multiple voids in a static shape using the menu Shape > Manual Void Cavity > Move. With the layer in question visible, choose this command, select the shape and then box select…
  • John T
    +1 John T over 2 years ago
    Hi Masamasa, we can select multiple voids in a static shape using the menu Shape > Manual Void Cavity > Move. With the layer in question visible, choose this command, select the shape and then box select all the voids within that shape.
    It could also be helpful to use the "pick tool" to enter the origin as the pick up location and then increment to the new location. Snapshot of this here:
  • masamasa
    0 masamasa over 2 years ago in reply to John T
    thank u for ur response.
    yes i was able to move voids.
    i hope move command includes this feature.
    regards
    masa
