  3. dbid:removed after first iteration
  • State Suggested Answer
  • Replies 10
  • Answers 1
  • Views 5103
Henry Monro
Henry Monro over 2 years ago
Below attached is the code on which I am working and its working for the first iteration only then it removes the DBIDs.
My motive is to create void on Selected vias using the DRC and the tool should create void on all selected vias. Have used axlDBRefreshId(nil) also but it didnt worked for me, maybe I didnt place the command on correct line of code.
Please help in this regard.
count=0
axlSetFindFilter(?enabled list("noall") ?onButtons list("noall"))
axlSetFindFilter( ?enabled '("alltypes") ?onButtons "DRCS")
axlSelect(?prompt "\nSelect DRCS from the layout")
drcs=axlGetSelSet()
length_l_drcs=length(drcs)
println("length_l_drcs")
println(length_l_drcs)
count=0
foreach(drc, drcs
if(drc->waived==nil && drc->name== "Drill Hole to Shape Same Net Spacing" then
drc_layer = drc->layer
drc_expected = drc->expected
drc_expected = parseString(drc_expected " ")
drc_expected = car(drc_expected)
drc_expected = atof(drc_expected)
drc_expected = (drc_expected+5)
l_violations=drc->violations
length_l_violations=length(l_violations)
;println("length_l_violations")
;println(length_l_violations)
if(length_l_violations <= 1 || length_l_violations >= 3 then
axlUIConfirm("Not a correct DRC")
foreach(violation l_violations
if(violation->objType=="pin" || violation->objType=="via" then
pv1 = violation
if(violation->objType=="shape" then
shape1 = violation
l_poly_shape = axlPolyFromDB(shape1)
voidPolys = nil
l_location=list(pv1->xy, drc_expected)
rpath = axlPathStartCircle(l_location, 0.0)
poly_circle = car(axlPolyFromDB(rpath))
voidPolys = cons(poly_circle, voidPolys)
openShape = axlDBOpenShape(shape1->shapeBoundary)
foreach(poly, voidPolys
axlDBCreateVoid(openShape, poly)
shape1 = car(axlDBCreateCloseShape(openShape))
axlShapeDynamicUpdate(shape1 t)
count++
println(drc)
  • DE202408202727
    0 DE202408202727 over 2 years ago in reply to Henry Monro
    What happens?
  • Henry Monro
    0 Henry Monro over 2 years ago in reply to DE202408202727
    Its still creating void on first only
  • DE202408202727
    Does this fix it:
    count=0
    drcs = nil
    mypopup = axlUIPopupDefine(nil, list(list("Done" 'axlFinishEnterFun), list("Cancel" 'axlCancelEnterFun)))
    axlUIPopupSet(mypopup)
    while(axlSelect(?prompt "Select DRCS from the layout")
    drc = car(axlGetSelSet())
    when(drc->name == "Drill Hole to Shape Same Net Spacing" && length(drc->violations) == 2
    drcs=cons(drc, drcs)
    axlClearSelSet()
    printf("length_l_drcs: %d\n", length(drcs))
    shapeList = nil
    foreach(drc, drcs
    unless(drc->waived
    pvXY = car(setof(violation, drc->violations, violation->objType=="pin" || violation->objType=="via")) ->xy
    drc_clearance = axlMKS2UU(drc ->expected) || 0 + axlMKSConvert(5, "mils")
    l_location=list(pvXY, drc_clearance)
    shape = car(setof(violation, drc->violations, violation->objType=="shape"))
    shapeList = cons(list(shape, l_location), shapeList)
    println(drc)
    count=0
    foreach(shape, unique(mapcar('car, shapeList))
    voidPolys = nil
    foreach(item, setof(item, shapeList, car(item) == shape); Get the list of drcs to this shape
    l_location = cadr(item)
    openShape = axlDBOpenShape(shape->shapeBoundary)
    foreach(voidPoly, voidPolys
    axlDBCreateVoid(openShape, voidPoly)
    count++
    shape = car(axlDBCreateCloseShape(openShape))
    ;axlShapeDynamicUpdate(shape t)
    count
  • Henry Monro
    It now shows the warning for multiple shapes and I have to run the code separately for each shape which takes time.
    Below is the warning that arises:
    *WARNING* (axlDBOpenShape): Invalid database id argument - nil
    Below is the snap as how I have the case:
    I would be thankful if you can help in this regard
  • DE202408202727
    I guess I should have tried this on a "real" design.
    Try this:
    count=0
    drcs = nil
    axlClearSelSet()
    shapeList = nil
    foreach(drc, drcs
    unless(drc->waived
    shape = car(setof(violation, drc->violations, violation->objType=="shape")) ->shapeBoundary
    println(drc)
    count=0
    voidPolys = nil
    openShape = axlDBOpenShape(shape)
    count++
    count
