  3. dbid:removed after first iteration
  • State Suggested Answer
  • Replies 10
  • Answers 1
  • Views 5097
Henry Monro
Henry Monro over 2 years ago
Below attached is the code on which I am working and its working for the first iteration only then it removes the DBIDs.
My motive is to create void on Selected vias using the DRC and the tool should create void on all selected vias. Have used axlDBRefreshId(nil) also but it didnt worked for me, maybe I didnt place the command on correct line of code.
Please help in this regard.
count=0
axlSetFindFilter(?enabled list("noall") ?onButtons list("noall"))
axlSetFindFilter( ?enabled '("alltypes") ?onButtons "DRCS")
axlSelect(?prompt "\nSelect DRCS from the layout")
drcs=axlGetSelSet()
length_l_drcs=length(drcs)
println("length_l_drcs")
println(length_l_drcs)
count=0
foreach(drc, drcs
if(drc->waived==nil && drc->name== "Drill Hole to Shape Same Net Spacing" then
drc_layer = drc->layer
drc_expected = drc->expected
drc_expected = parseString(drc_expected " ")
drc_expected = car(drc_expected)
drc_expected = atof(drc_expected)
drc_expected = (drc_expected+5)
l_violations=drc->violations
length_l_violations=length(l_violations)
;println("length_l_violations")
;println(length_l_violations)
if(length_l_violations <= 1 || length_l_violations >= 3 then
axlUIConfirm("Not a correct DRC")
foreach(violation l_violations
if(violation->objType=="pin" || violation->objType=="via" then
pv1 = violation
if(violation->objType=="shape" then
shape1 = violation
l_poly_shape = axlPolyFromDB(shape1)
voidPolys = nil
l_location=list(pv1->xy, drc_expected)
rpath = axlPathStartCircle(l_location, 0.0)
poly_circle = car(axlPolyFromDB(rpath))
voidPolys = cons(poly_circle, voidPolys)
openShape = axlDBOpenShape(shape1->shapeBoundary)
foreach(poly, voidPolys
axlDBCreateVoid(openShape, poly)
shape1 = car(axlDBCreateCloseShape(openShape))
axlShapeDynamicUpdate(shape1 t)
count++
println(drc)
  • DE202408202727
    0 DE202408202727 over 2 years ago
    The dbids are changed the instant you process the first shape. To avoid this you need to "cache" the changes for each shape.
    Try this:
    count=0
    drcs = nil
    mypopup = axlUIPopupDefine(nil, list(list("Done" 'axlFinishEnterFun), list("Cancel" 'axlCancelEnterFun)))
    axlUIPopupSet(mypopup)
    while(axlSelect(?prompt "Select DRCS from the layout")
    drc = car(axlGetSelSet())
    ;when(drc->name == "Blind/Buried Via to Shape Same Net Spacing" && length(drc->violations) == 2
    when(drc->name == "Drill Hole to Shape Same Net Spacing" && length(drc->violations) == 2
    drcs=cons(drc, drcs)
    axlClearSelSet()
    printf("length_l_drcs: %d\n", length(drcs))
    shapeList = nil
    foreach(drc, drcs
    unless(drc->waived
    shape = car(setof(violation, drc->violations, violation->objType=="shape"))
    shapeList = cons(list(shape, drc), shapeList)
    println(drc)
    count=0
    foreach(shape, unique(mapcar('car, shapeList))
    voidPolys = nil
    foreach(item, setof(item, shapeList, car(item) == shape); Get the list of drcs to this shape
    drc = cadr(item)
    pv = car(setof(violation, drc->violations, violation->objType=="pin" || violation->objType=="via"))
    drc_clearance = axlMKS2UU(drc->expected) + axlMKSConvert(5, "mils")
    l_location=list(pv->xy, drc_clearance)
    openShape = axlDBOpenShape(shape->shapeBoundary)
    foreach(voidPoly, voidPolys
    axlDBCreateVoid(openShape, voidPoly)
    count++
    shape = car(axlDBCreateCloseShape(openShape))
    axlShapeDynamicUpdate(shape t)
    count
    • Vote Up -1 Vote Down
  • Henry Monro
    0 Henry Monro over 2 years ago in reply to DE202408202727
    Still just making the first void only. Then removing the DBIDs
  • DE202408202727
    0 DE202408202727 over 2 years ago in reply to Henry Monro
    Oh yes. I had it working then made the same mistake  of expecting the drc dbids to not be changed.
    Try this:
    count=0
    drcs = nil
    axlClearSelSet()
    shapeList = nil
    foreach(drc, drcs
    unless(drc->waived
    shapeList = cons(list(shape, pv, drc ->expected), shapeList)
    println(drc)
    count=0
    voidPolys = nil
    pv = cadr(item)
    drc_clearance = axlMKS2UU(caddr(item)) + axlMKSConvert(5, "mils")
    count++
    count
  • DE202408202727
    0 DE202408202727 over 2 years ago in reply to DE202408202727
    I slept on it and I think this has more chance of working:
    count=0
    drcs = nil
    axlClearSelSet()
    shapeList = nil
    foreach(drc, drcs
    unless(drc->waived
    pvXY = car(setof(violation, drc->violations, violation->objType=="pin" || violation->objType=="via")) ->xy
    drc_clearance = axlMKS2UU(drc ->expected) + axlMKSConvert(5, "mils")
    l_location=list(pvXY, drc_clearance)
    shapeList = cons(list(shape, l_location), shapeList)
    println(drc)
    count=0
    voidPolys = nil
    l_location = cadr(item)
    count++
    count
  • Henry Monro
    Both of them are not working.
