  3. Funckey for Net schedule ?
  • State Suggested Answer
  • Answers 2
  • Views 5994
kabalee
kabalee over 2 years ago
Hi Team,
i am using some funckey comment for add via , Move , rotate and  route
is any function key for Net schedule ?
example :
funckey r rotate
funckey g define grid
funckey m move
funckey t status
funckey 1 color19
please response any one.
  • steve
    0 steve over 2 years ago
    Yes try funckey X net schedule. Tip:- if you type scritpmode +e at the command line in Allegro followed by a return this then reports the command names used.
  • Nayyier Kazi
    0 Nayyier Kazi over 2 years ago in reply to steve
     if we need to assign key for route finish then what we should write after scriptmode +e?
  • steve
    0 steve over 2 years ago in reply to Nayyier Kazi
    funckey X pop finish. This will ONLY work if you already in route mode (i.e. Invoke Route connect, pick up a net and start routing then press X which will finish the route).
