  3. overlapped vias
  • State Suggested Answer
  • Answers 1
  • Views 5727
overlapped vias
masamasa
masamasa over 2 years ago
hello
is there a way to find the locations of overlapped vias (same net) as shown below?
regards
masa
  • VVRD
    VVRD over 2 years ago in reply to masamasa +1 suggested
    Hope this helps, Article (20491484) Title: Allegro DesignTrue DFM Stack Microvia over Core Via Rules URL: https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1O3w000009xxoIEAQ
  • DavidJHutchins
    0 DavidJHutchins over 2 years ago
    Have you looked at the conversation 'How to create DRC marker to find overlapped via on Though pad?' to see if it's solution would work in your design?
  • masamasa
    0 masamasa over 2 years ago in reply to DavidJHutchins
    thank u for ur respose, david
    although it is not thru pins, let me try this as bb vias can be similar with thru pins.
    regards
    masa
  • VVRD
    0 VVRD over 2 years ago in reply to masamasa
    Hope this helps,
