  3. Swapping of layers on the PCB Board
  • State Suggested Answer
  • Answers 2
  • Subscribers 166
  • Views 7471
RohitRohan
RohitRohan over 2 years ago
Dear Community,
I have a 6 layer PCB board which has clines, shapes / etches, via in all the layers, I want swap these from one layer to another layer, like there is layer 3 which has clines, shape / etches, I want to swap layer 3 to layer 4.
  • avant
    avant over 2 years ago +1 suggested
    You can use the edit / change / cline to change the cline to another layer.
  • JuanCR
    0 JuanCR over 2 years ago
    Hello Rohit,
    You can always use the Z-copy command. There are couple articles in the COS site that explain how to use it. Here's the link to them:
    Article (11009846) Title: How to copy a cline to another layer in Allegro
    URL: https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od0000000nboiEAA
    Article (20204744) Title: How to copy a shape to several classes across the board.
    URL: https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od0000000tMieEAE
    And here's the content of one of them (you can use the same procedure but applied to different elements):
    1. Select Edit > Z-Copy.
    1. Select only Clines in the Find filter.
    1. In the Options window, change Copy to Class/Subclass to the new subclass to which you want to copy the cline.
    1. Select the clines individually or using a rectangular selection.
    2. With the clines highlighted, right-click and select Done from the pulldown menu.
    You will see a copy of the cline/s on the destination subclass.
  • avant
    0 avant over 2 years ago
  • masamasa
    0 masamasa over 2 years ago
    for swapping layers, i would use 2 files, file a with layer 3 (removed layer 4) and file b with layer 4 (removed layer 3).
    with z-copy command, u can move objects on layer 3 to layer 4 on file a and objects on layer 4 to layer 3 on file b.
    u can import layer 4 of file a into file b by sub-drawing.
    u would need to adjust the padstacks.
  • avant
    0 avant over 2 years ago in reply to masamasa
    Here's an easier method:
    Move the clines on layer 3 to clear the board outline. for example, move clines ix 50.
    Use Edit/Change/Cline to change the clines on layer 4 to layer 3.
    Change the clines that were moved to be on layer 4. Move those clines back ix -50.
    To keep any existing vias from connecting to planes when the clines were moved, you can use Edit/Property/Vias to assign property "Retain Net".
