  3. Allegro 23.1 with HF 006 Graphic Issues on Latest VMware...
  • State Verified Answer
  • Views 7769
Allegro 23.1 with HF 006 Graphic Issues on Latest VMware Workstation Pro
cstocci52
cstocci52 over 2 years ago
Folks,
Is anybody else operating the latest Allegro on VMware Workstation Pro VM and getting the "occasionally disappearing" layout?  It always comes back in, but one needs to click outside the window or pull down another fly-out menu item to get the screen contents to re-appear.  The 3Dx option opens fine, but there is no PCB present when it is present in the older 3D Mapper window.  Is this just a "thing" with virtual machine graphic drivers?
  • JuanCR
    JuanCR over 2 years ago in reply to cstocci52 +1 verified
    What operating system are you running in your VM? I can give you a few things to try: 1. Disable accelerate 3D graphics in VMware display setup 2. setenv noopenglgraphics 1 in .cshrc file 3. Set…
  • JuanCR
    0 JuanCR over 2 years ago
    Hi cstocci52
    Can you elaborate on the "occasionally disappearing" section?
  • cstocci52
    0 cstocci52 over 2 years ago in reply to JuanCR
    Hi JaunCR,
    Whenever I move the mouse cursor (not always, but many times) over some part of the layout, the entire picture of the layout goes black and only when I click elsewhere or open up another menu sub-item does the image of my layout re-appear.  I also see NOTHING when I click on the 3Dx viewer even though when I export, my eDrawings 3D STEP viewer sees everything just fine, so there is 3D data, I just cannot see it in Allegro's 3Dx screen.  I kind of thought it is something to do with these virtual machine video/graphics drivers which are not the best.
    What are your thoughts.  BTW, I am running Allegro 23.1 HF006 on VMware Workstation Pro v 17.5x.
    CT
  • JuanCR
    +1 JuanCR over 2 years ago in reply to cstocci52
    3. Set disable opengl in ENV file
    4. Use allegro -safe -noopengl to launch the tool
    However, due to the restrictions inherent with virtual and remote desktop environments, Cadence does not test, certify, or support any of the graphical applications in any virtual environment. Virtual environments include, but are not limited to: Citrix, VMware, and Hyper-V. Remote desktop environments include but are not limited to: Remote Desktop (Windows), Hummingbird (Windows), Remote X Desktop (Linux), and VNC based products (Windows and Linux).
  • cstocci52
    Hi JuanCR,
    Answers to your questions:
    Software => VMware Workstation Pro v 17.5.2
    Host System => Windows 10 Professional
    Guest VM System => Windows 11 24H2 Enterprise LTSC
    1. I did try disabling the 3D Accelerator in the VM properties, but then the Allegro 3Dx in the W11 VM would not even attempt to run telling me I needed to install Direct 3DX or something similar.  Other 2D stuff worked fine.
    2. 3. and 4.  Did this and because there was no opengl, the 3Dx menu was present, but when activated, I get "Warning(SPMH3D-10) the 3DX engine is not available in the current environment.  Disabled by the enviromental option "disable_opengl""  That was it!
    Evidently, the new Allegro 3Dx or, in general the Allegro X product does not like running in a VM because when I ran it as a normal Allegro without the "X" in the safe mode, everything is stable and no "black-out" of the layout contents, but no 3Dx capability other than the 3D mapper function which has been around for a while.  This issue is clearly related to the insufficient graphics capability within any VM.
    Thanks for helping out!
  • JuanCR
    0 JuanCR over 2 years ago in reply to cstocci52
    No problem CT,. Glad I could help.
    Even though it's not officially supported, I have seen people run Allegro in VM environments. So, like you said, it is very likely that Allegro X (being a new version) is still unstable in such environments.
