  3. Error(SPMHDB-180): Design revision 23.1 is newer that current...
  • State Verified Answer
  • Views 5371
Error(SPMHDB-180): Design revision 23.1 is newer that current program version
Edit slide getting closed
Edit slide getting closed over 2 years ago
Hi Team,
Our current version 17.4
  • Robert Finley
    Robert Finley over 2 years ago in reply to Edit slide getting closed +1 verified
    With Orcad X 23.1, there's an >Export dialog towards the right, after >Manufacture. >Export >More >Down Rev Design I think it's in a different menu location(next to >File maybe) for Allegro 23.1 but…
  • Robert Finley
    0 Robert Finley over 2 years ago
    Someone took a 17.4 database, saw the warning that any saves would upconvert the data to 23.1 and forgot.  Saved over the 17.4
    Find someone with 23.1 installed and have them down-rev changes back to 17.4.
    There are minor padstack and design features added in 22 and 23 that will be dropped when down-reving to 17.4.
  • Edit slide getting closed
    0 Edit slide getting closed over 2 years ago in reply to Robert Finley
    Hi Sir,
    Thanks much for your response.
    We have 23.1 version also. How to down rev? Could you please help with this?
  • Robert Finley
    +1 Robert Finley over 2 years ago in reply to Edit slide getting closed
    I think it's in a different menu location(next to >File maybe) for Allegro 23.1 but right now one my engineers is using my Algx license.
    Thanks much for your support.
    Problem solved
