  3. How to adjust endcap styles of static shapes, dynamic shapes...
  • Replies 8
  • Subscribers 166
  • Views 9437
How to adjust endcap styles of static shapes, dynamic shapes, and clines
aniju
aniju over 2 years ago
Allegro PCB Editor offers a feature, endcap style, to avoid acid traps during the PCB etching process. This feature helps mitigate the risk of acid traps by adjusting the design to ensure smoother transitions and rounded corners where needed. This results in a more reliable and manufacturable PCB layout.
 Two types of endcap styles are available in Allegro PCB Editor: av_endcapstyle and av_endcapstyle. You can set these using Setup > User Preferences and choosing the Shape > Voiding category.
av_endcapstyle: Setting this variable will determine the shape of a void around a cline for static shapes. There are three styles available: round, square, and octagon. Once set, you can see the shape voids, as shown below:
dv_endcapstyle: This variable specifies the geometry of the void created around the endpoint of a cline for dynamic shapes. There are two styles available, round and octagon. By default, it will be round.
You can also set up the appearance of “Connect Line Endcaps”, which means how the endpoint of vertices of lines and clines are displayed on the screen. To set this, go to Setup > Design parameters > Display and enable “Connect Line Endcaps”.
You can see that the clines will now have rounded vertices compared to 90-degree vertices when this option is not enabled.
The choice between 90-degree and rounded vertices can significantly impact the visual outcome of the design. The “Connect Line Endcaps” option provides flexibility in how these vertices are rendered, allowing designers to customize the appearance to suit the specific needs of the project.
  • avant
    avant over 2 years ago
    Can you clarify the purpose? Are these unconnected dangling lines? I guess it could be helpful for the end of an antenna trace.
  • Bennigin
    Bennigin over 2 years ago in reply to avant
    The description for both also says "Avoid using this variable" and "not recommended". Any idea why?
  • aniju
    aniju over 2 years ago in reply to Bennigin
    Thank you for your message. I have reached out our R&D team regarding these variables to get a better understanding of their plans. Please stand by.
  • masamasa
    masamasa over 2 years ago
    hello
     how come this option is not set up as default?
    it is very difficult to see a cline-to-cline connection without endcaps.
    with endcap, the clines r connected smoothly as shown below
    regards
    masa
  • mahimag
    mahimag over 2 years ago in reply to masamasa
    masamasa , you can turn them on in Setup > Design parameter and then for new design also it will remain turned on.
