  3. How to change the drawing origin for the PCB layout in OrCAD...
  • State Suggested Answer
  • Answers 1
  • Views 7318
How to change the drawing origin for the PCB layout in OrCAD X Presto
RohitRohan
RohitRohan over 2 years ago
Dear Community,
I wanted to know how the change the PCB board drawing origin in the OrCAD X Presto.
In the normal legacy PCB layout its Setup >> Change Drawing Origin (Below image), but i want to know how to perform the same in the OrCAD X Presto (OrCAD X Professional).
Rohit Rohan
  • techiecs
    techiecs over 2 years ago +2 suggested
    While selecting the design outline in OrCAD X Presto, you can see the option of changing 'Design Origin' in the Properties Panel in the right-side of the canvas. Here you can select the option 'Pick Origin…
  • avant
    0 avant over 2 years ago
    Under Setup / Design Parameters / Design, you can move the origin by entering values in the "X" and "Y" boxes.
  • techiecs
    0 techiecs over 2 years ago
    While selecting the design outline in OrCAD X Presto, you can see the option of changing 'Design Origin' in the Properties Panel in the right-side of the canvas. Here you can select the option 'Pick Origin Location' after which Session Log asks you to 'Pick new location for drawing origin' and you can select the new origin location in the design canvas here.
    • Vote Up +2 Vote Down
