  3. Artwork will be rounded down because the database is in...
  • State Suggested Answer
  • Answers 1
  • Views 5863
Artwork will be rounded down because the database is in MILS with precision 3 requiring artwork precision of 7 decimal places, which is greater than the maximum of 6.
RohitRohan
RohitRohan over 2 years ago
Artwork will be rounded down because the database is in MILS with precision 3 requiring artwork precision of 7 decimal places, which is greater than the maximum of 6. Rounding down might result in inaccurate arc coordinates in the output files and possible shape/void plotting failures. For raster artwork formats, artwork accuracy must be at least one place greater than the database accuracy, up to the maximum accuracy allowed by the selected output format. Use GDSII or IPC2581 manufacturing format that support the level of database accuracy set.
Hai Community,
I am getting above error during the artwork creation, the design parameters had been changed from mm to mills during the creation of the PCB board.
How I can fix this above issue.
If I go to Manufacture >> Artwork (Below image) >> in the format Decimal places I am not able increase more than 6.
  • JuanCR
    JuanCR over 2 years ago +1 suggested
    Hi Rohit This is a tool as well as possibly a manufacturing limitation. Please take a look at the following document that touches upon this subject: community.cadence.com/.../AllegroDesignAcc.pdf
  • JuanCR
    0 JuanCR over 2 years ago
    Hi Rohit
