  3. OrCADX_23.1 : how to show default PPr (PinPair) associated...
  • State Verified Answer
  • Views 5389
OrCADX_23.1 : how to show default PPr (PinPair) associated to EVERY Xnet / Net ? +other questions on PPr
grax
grax over 2 years ago
Hi
Q1: How is possible to show PinPair for EVERY Xnet / Net  inside Constraint Manager?
Q2: Is there any DEFAULT PinPair created together with Xnet / Net ??
What I mean is that the topology associated to Xnet is done by the CAD tool and can be analyzed graphically by SigExplorer; but there is no information regarding the PPr which will be used at the end by the router (RePPr?)
Q3: In some doc I found RePPr which correspond to Result-PinPair, could you explain what is the difference respect to a normal PinPair? who to show RePPr ?
Q4: Inside Constraint Manager I discovered I can setup PINUSE (OUTPUT and INPUT) on CM > PROPERTIES > COMPONENTS > PIN PROPERTIES > PINUSE; this FUNDAMENTAL parameter does affects how Xnet are generated. Is it possible to REBUILD new Xnet set AFTER modifing PINUSE ?? this would be VERY USEFULL since PINUSE is NOT accessible from the SCHEMATIC and changing the Pin Type inside the schematic is quite complicated (lib issues)
Q5: imagine a simple TX > lane > RX / then PIN TX driver has NOT been configured as OUTPUT nor the RX as INPUT.
The serpentine compensation must be done close to the RX
How to OBLIGE the PCB engineer to route starting from the TX pin and not from the RX pin? in which case the serpentine routing compensation will be ERRONEOUSLY located close to RX
Thanks in advance for your support
L
  • grax
    grax over 2 years ago +1 verified
    SOLUTION From constraint manager > Properties > Components.PINS then use the field PINUSE to set the PIN as OUTPUT or INPUT This will impact PinPair generation PPre(sulting) is always automatically provided…
  • grax
    0 grax over 2 years ago
    Sometimes the PPr are generate INVERSED. Pin1 = Rx and Pin2 = Tx / how to swap them ??
  • grax
    +1 grax over 2 years ago
    SOLUTION
    PPre(sulting) is always automatically provided after that ANALYSIS has been processed
