  3. Resize window/resolution issue
  • State Suggested Answer
  • Replies 7
  • Answers 1
  • Views 5314
yu88
yu88 over 2 years ago
Anyone faced this issue? I cant see the full information on the window. I could see when lower the screen resolution.
is the an option to resize the window or anyone have solution for this?
  • yu88
    yu88 over 2 years ago in reply to mahimag +1 suggested
    i did set this to my OS system variable (since 17.2). Now i try to remove it and it solved the problem!! So i think maybe Cadence improve high resolution display in 17.4 and we dont need " ALLEGRO_HIGH_DPI_ENABLED…
  • yu88
    0 yu88 over 2 years ago
    when i change display resolution from 3840x2160 to 1920x1200
  • mahimag
    0 mahimag over 2 years ago in reply to yu88
    Hello @yu88, some dialog boxes are fixed and cannot be resized. Recommended resolution is 3840x1600 which works fine at my end.
  • yu88
    0 yu88 over 2 years ago in reply to mahimag
    yes, i know some are fixed. It works fine too for 17.2. but it is not when i upgrade to 17.4. My resolution is 3840x2160 (recommended)
  • mahimag
    Can you try Reseting the UI to Default once by going to View > UI Settings > Reset UI to Default?
    Also, try renaming your allegro.geo file in your pcbenv folder
  • yu88
    i have try this but unfortunately it does not help.
