  3. Unable to import files in OrCAD
  • State Verified Answer
  • Views 5820
Isha
Isha over 2 years ago
Hi Everyone,
I am trying to Import Altium files in OrCAD by performing the following steps
  • File >> Import >> Altium Translator >> Browse the PrjPCB file >> Translate
I am getting the following error when i perform it
But I am able to import with the help of ASCII format and also with .SchDoc
Can anybody provide the solution
  • Jeet
    Jeet over 2 years ago +1 verified
    This error generally occurs when the schematic design in Altium is not saved in an Advanced Schematic ascii (ASCII) format. The Schematic has to be saved to ASCII format within Altium. This replace the…
  • Jeet
    +1 Jeet over 2 years ago
    This error generally occurs when the schematic design in Altium is not saved in an Advanced Schematic ascii (ASCII) format. The Schematic has to be saved to ASCII format within Altium. This replace the original binary file by its ASCII equivalent. Once you save the design in the ASCII format in Altium, you should be able to import the Altium design into OrCAD Capture without any error.
    You can see more details about Importing Altium Schematic in OrCAD Capture by going to File > Import > Altium Schematic Translator > Help.
    Hope this helps!
  • Isha
    0 Isha over 2 years ago in reply to Jeet
    Thank you very much
