  3. AllegroX QUICKPLACE: how to use "PLACE BY ASSOCIATED COMPONENTS...
  • State Suggested Answer
  • Answers 1
  • Views 1740
AllegroX QUICKPLACE: how to use "PLACE BY ASSOCIATED COMPONENTS" to get decoupling capacitors of a POWER RAIL
grax
grax over 2 years ago
Hi
which is the property/value to be added to a IC SYMBOL in order to be listed in PLACE BY ASSOCIATED COMPONENTS during Quickplace??
I want to get all decoupling capacitors associated to an IC
thanks
  • DavidJHutchins
    DavidJHutchins over 2 years ago +1 suggested
    The COMPONENT_WEIGHT property is the only one I can find in the documentation...
  • DavidJHutchins
    0 DavidJHutchins over 2 years ago
  • DavidJHutchins
    0 DavidJHutchins over 1 year ago in reply to DavidJHutchins
    I opened a SysCap design & added decoupling caps to a connector, saved & exported to layout
    I then opened the layout & used quickplace to place those caps
    using 'show element' on the 'functions' of the connector I found it has the property:
    CDS_FUNC_IDENT              = 5a54ab2e-a22c-4647-81a7-dbe8f4005229
    Then looking at 1 of the caps it has the property:
    CDS_PARENT_FUNC_IDENT  = 5a54ab2e-a22c-4647-81a7-dbe8f4005229
    neither properties are documented in 'Allegro X Platform Properties Reference'
