  3. adding parallel lines
  • State Suggested Answer
  • Answers 1
  • Subscribers 163
  • Views 5229
masamasa
masamasa over 2 years ago
hello
i am trying to add parallel lines but whenever i do it, the offset value changed back to 2540.00
is there a way to retain the last used value for the offset value?
regards
masa
  • John T
    0 John T over 2 years ago
    Hi Masamasa, yes I can see this issue repeated on my machine. I have checked it just now. This appears to be an oversight on our part. Let me raise an enhancement request internally to ask for the values entered to be retained.
    However, if you enter a value while in command, you can copy offset several lines in succession and the offset value is retained for the duration of these multiple operations. Have you found this also?
  • John T
    0 John T over 2 years ago in reply to John T
    I have now created the Cadence Change Request (CCR) number  3047246 for this enhancement.
  • masamasa
    0 masamasa over 2 years ago in reply to John T
    thank u, john.
    i hope the next hotfix include this.
    regards
    masa
