  3. converting a cline to a shape
  • State Verified Answer
  • Answers 1
  • Views 7692
masamasa
masamasa over 2 years ago
hello
is there a way to convert a cline to a shape?
regards
masa
  • techiecs
    techiecs over 2 years ago +1 verified
    You can convert clines in your designs to shapes, follow the below steps- 1 Go to menu Tools> Convert> Cline/Line to Shape. 2 Choose the required checks in the Options panel. 3 Select the clines that you…
  • jc teyssier
    0 jc teyssier over 2 years ago
    Just search with words cline shape
    You will get this result:
    community.cadence.com/.../axlskill-function-to-convert-a-cline-to-a-shape
  • techiecs
    +1 techiecs over 2 years ago
    3 Select the clines that you want to convert to shapes, do RMB and select Done from the pop-up menu.
  • jc teyssier
    0 jc teyssier over 2 years ago in reply to techiecs
    I do not have this menu: maybe because i use 17.2
    From which version this feature appear?
  • techiecs
    0 techiecs over 2 years ago in reply to jc teyssier
    I saw this option from 22.1 version onwards.
  • masamasa
    0 masamasa over 2 years ago in reply to techiecs
    thank u, i was able to convert a cline to a shape with 17.4.
